lets get this clear for any new guys going right to the end.....they are not going to fix your truck. tire issue...lolol. I asked them from the beginning " do u have any trucks that don't vibrate?" after a perfectly practiced shock face, they picked one.. I told them to switch rims and tires. even offered to pay for labor to eliminate the argument then and there. was done - truck acted the same. mines a '14 and still hearing problems with even the newest ones. don't forget - this is gm - they will let people die before recalling a major issue ( ignition ) so... u think they care about a vibe? - u got 2 choices - live with it - or go directly for a buy back. this has been going on for years.
Oh, I didn't see the 1500 sub-forum, was coming in from a search result in Google. Well that gives me hope that my case might be easier to fix. Now I feel bad for all you 1500 guys.
GM really needs to get their quality straightened out. I also own a Vette... total nightmare.
It doesn't matter, put it in here as well, maybe we can try and narrow it down one day when we have all the Suv's and trucks in this thread. Combine it all.
I own a 2016 GMC Sierra 1500 SLE Crew Cab 5.3L z71 with p265/65/18. No vibration when I initially bought vehicle new. @20k miles I took vehicle to dealership for oil change and they found nail in rear driver side tire and offered to patch tire. After they patched tire there was vibration at 75mph. Took it back to dealer and they said it would be $49 to balance tire. Told them to forget it, I'll try to stay below 75 and wait until I get some new tires. @27k miles I still had the vibration at 75 mph until I took it to dealer again for oil change and tire rotation. Vibration is now gone. Seems the rear is more sensitive with proper balanced tires then the front.
Hope this helps somebody.
I have a 3 week old 2017 LT Z71 DC with 1400 miles on it and Good Year Duratrac's of the same size (265/65/18). I have no noticeable or concerning shake. Knock on wood. I regularly cruise the highway at various speeds from 55-80.
Is it known to be less of an issue with any particular tire size?
I disagree. I think the way GM can ignore the un-fixable vibration is aided by every possible shimmy, shake and vibration being lumped into one bunch. So far as I've read there are at least 3 distinct problem vibrations with this platform beyond the issues that can affect every make (like unbalanced tires, bent driveshafts, etc..
1. roof panels of the SUVs were flexing at a rate owners were calling it a vibration, coupled with a thunderous noise inside the cabin as if a sunroof is open too far. - fixed by somehow attaching the roof panels to the chassis better?
2. Vibration due to dropping from 8cyl to 4cyl. - Seems to me this is fixed by a flash, didn't read too much into it since this isn't my problem.
3. The actual, un-fixable, un-explainable, and inconsistent shaking that can happen in the 62-68mph range, but more commonly in the 72-80mph range.
I had number 3. Had, being the operative word because I have a rockstar attorney that successfully sued under lemon law. I'm done with GM for now, but will keep checking back to see if they ever get this sorted out. If it didn't drive me mad on long trips I could have really loved my 16 CC ltz-z71. It had a very nice interior, superior electronics package, and the 6.2l coupled with the 8spd transmission had me consistently achieving 25-27mpg on the highway.
By the way, has anyone been able to get their service department to give them a readout of the pico scan? And beyond that, document the numbers vs. whatever 'Spec' is? Too many people I know are being told 'it is performing within spec' and when pressed, the dealership will not give numbers.
In regards to the pico scan, I like you, was unable to get a readout from the dealership. I also found it peculiar that they mounted it to the rear seat and called it a day. I explained it was mostly felt through the steering wheel and pedals, even had the service manager agree on the test drive but a day later after leaving my vehicle he seemed to have gotten amnesia after speaking with the higher ups and retracted his statement.
At this point in time after mounting my GoPro underneath the truck I can see clear as day the driveshaft at the transmission side is dancing around and even flexing under load pulling the rear of the transmission along with it. I removed my driveshaft and took it to a reputable driveline shop and he explained to me that the overall design of the driveshaft is junk. As well as it not being balanced, it is way out of spec in regards to straightness and is even oval shaped. With the swedge design at the ends of the shaft the out of round high and low spots as well don't even match up with the highs and lows on the main 5" section. There is no way to fix it and have a legitimate shop warranty it so I pulled the trigger and have them building me a new 5" straight shaft with spicer joints for $650. I am picking it up this afternoon and will follow up if its a successful story.
Has anyone successfully won a lemon law suit for the shake? I work with a guy that has a 2016 chevy 1 ton, DC, long bed that is going to pursue it if they can't fix it.
AGARubberDuck
Let's not forget the 35 to 50 mph vibration caused by a ring gear badly out of specs.
yes. Check the criteria for your state. It will need to have been in for repair for the same problem a certain number of times OR out of service for a certain number of days. Just be prepared for the process to take a very long time; I was driving loaners for 90 days out of the first 5 months before talking to my attorney. The suit took 4 months and could have taken longer if GM decided to go to court instead of settle.
Edited by AGARubberDuck
Take your driveshaft to a machine shop, for an hour of labour they will spin in up and check the balance, $75. GM will not help you. For example, say only 200,000 trucks total are affected, likely much more but for estimate sake. If the remedy was found to be replacing the driveshaft, yoke and u joints, the parts cost is roughly $500 per unit. That equates to $100,000,000 before labour. Add 1 hr of labour at industry average of $75. Total warranty program cost $115,000,000 GM is not going to do anything about it until people start crashing and getting hurt.
I actually did this. Interestingly, the shop stated they typically accept a tolerance of 0.005" or less deflection at 2200rpm to be the number they aim for when balancing a driveshaft. Mine measured out to 0.0005". "dead on the nuts" was his exact words. No dents, out-of-roundness or defects of any kind.
This problem has taken up so much room in my head for the past 10 months I'm thinking about all kinds of odd possibilities. Maybe it is actually an aerodynamic problem? Seems everything from the transmission back through the tires has been ruled 'in spec' or better. Heck, I even received new shocks as they had 2" of dead travel, suspecting they were introducing the problem. (obviously they were worn out after only 9k miles of dampening a horrible shake) But if this truck is indeed super light and ridged, maybe as you drive at highway speeds, typically in the 70+mph range, there is enough downforce to start oscillating the onto the suspension. I can drive on the same stretch of road day after day, some days it's shaking so hard I'd feel nauseous. Other days it is smooth as glass. Most days are in the realm of "this COULD be the road" but I know better. Maybe this is at least partly explained by wind speed and direction.
Who knows.. not my problem any longer :D Now I just need to forget about it this unsolvable problem.
.... Isn't there a FORD forum you F150 owners can join?
Just sayin........
I'm in some.... But this train wreck is too interesting to not keep an eye on.
The issue isn't them joining an F-150 forum, they typically do. But as soon as they let everyone know that they couldn't stand the vibration any longer and opted out Mook will get back up on his soap box and let them know what a horrible mistake they made lol You tell'em Mook !!!!
But those of us that have opted out can't stop watching this train wreck of a thread. I'm on my third new vehicle since I opted out and if it were not for this issue those three all would have been GM vehicles. But I will never buy GM again.
:driving:
Trolls [emoji115]
We paid our dues with this issue. we can be here if we want.
QUOTE! 100% guaranteed! I read your boys forms and all this nonsense at the time IDK 500 pages deep at the time......80% of it was BS nothing to do with problem........What are the chances I get one? Slim to none and would still have a GM over the others.....and if it did shake! I would have the dealer buy it back and I would get one that does not shake.....WOW
People still buy that F'N ecoboosts and nothing has changed about their CRAP either.....
Actually they did change the ecoboost. I researched the h*ll out of it before getting one. The major issue of condensation/water forming was resolved with a changed intake
The problem is more pervasive than you wish to believe. I'm not sure what makes you the subject matter expert. Are you a GM employee, engineer, or mechanic? Pointing the finger back at Ford, Dodge or Toyota doesn't make the vibration problem go away. Nor does it excuse Ford for the problems with the fecalboost motor. I didn't buy the fecalboost because I heard bad things about the early revisions.. gotta be careful with every make and every redesign. I went with the 5.0L V8 to avoid the new 10 speed tranny they have. Didn't want the 3.5L w/10speed and the 2.7L wasn't an option for me. And yes, brace yourself, GM is working with Ford on this 10 speed tranny design. Imagine that? Who knows what kind of crap they'll spin up here! What will the fanboys do now that they share transmissions?
Btw, the 5.3L is a nice motor. I actually agree with that. Its rock solid, very capable. Its the stuff they put around it that is the problem...
Back to the topic: there is a problem with this platform and that's a fact. How many have the vibration is unknown. Jury will be out until 2024-2027 and we get ten years of history to look at. I know at my dealer, the service rep readily admitted that there were alot of truck that had it and that GM didn't have a fix. He looked like a man that was sick of toeing the party line, which tells you he is sick of lying to customers. Its a big dealer and they do alot of business, for what its worth.
There are plenty of us out there that spend good money and expect a decent ride. Yes, its a truck and will drive like a truck. But vibrations like this are totally unacceptable. I'm sorry that some can't seem to wrap their heads around the fact that this problem exists... but it does. If you had the vibrations, you would not like your truck, I almost guarantee that. Almost, because some say they can live with it... or they don't drive 80 mph. So they don't care.
I'm ok in the $ .. hence the new 16 LTZ CC
Enough said ..done here moving on, Bill find some TOYO friends.
But he likes us all so much. don't ask him to leave!
@Bill, how long was it until your shocks were gone?
I agree with you, mine is the same way, some days the same road in the morning it will shake a little but not on the way home and some days it wont in the morning and it will on the way home, sometimes it starts at 72-73mph and sometime 77mph, i can watch my roll up cover on my bed while its shaking and it is fluttering in the same manner that the shake is. Not saying its the problem for all, but in a lot of peoples case sure it is, because when everything is good that rotates it has to be air flow/air density.
Edited by Silverado 6.2
I’ve been living with this vibration for 30,000 miles and I’m done with it.
I’ve started a YouTube series following my journey through the process.
I'm done with mine as well. Vibration will be fixed but I do feel bad for the next owner.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
