As discussed in a previous post. I went to my local 4WP and they told me about an issue they came across. Apparently on the 2WD trucks, the Automatic Transmission Extension Housings is damaged or not properly installed from the factory. The seal leaks (transmission fluid) and/or wears out prematurely and this causes .... wait for it ... our dreaded shake with the 2WD trucks. Definitely something fishy with the transmission and drive shaft. This has worked so far on a GMC and Chevy. The part number is ACDELCO 24224676. $75 for the part plus labor. Did it fix my shake? About 80% there. I can now get up to 90 MPH without the console throwing itself violently. Unfortunately the shudder between 30 and 55 MPH persists. I still have wheel hop, so that is probably attributed to the crap axles and the trash leaf springs. Good luck YMMV.
Thanks for the info. I found a GM service center that knows about the problem, but they have to go through GMs procedural crap. The shudder between 30-55mph is the torque converter. GM tech told me that himself. I'll keep this updated in case it helps anyone out. They'll start working on my truck next Tuesday.
Edited by lylknutsak
what about 4wd ? same problem ?
the problem with this vibration is an expensive fix to recall and apparently not life threatening or causing damage beyond uncomfortable ride
it may be expansive due to time or labor or parts no one can tell but GM .
So far this has only been performed on 2WD trucks.
The 4 wd has an adapter where the 2wd tail housing would bolt that connects the t-case to the transmission. It's just a hollow piece, not to say the t-case doesn't have issues at the intergrated tail piece where the drive shaft conncets. If that really is the issue it explains why GM doesn't want to fix it. 2 grand a pop plus labor for the t case.
Well, I'm out.
Traded the GMC in on a new truck and I am very happy about it.
Good luck guys - I really, really, really hope we do end up finding a solution...
What did you get?
Jim
can you at least put something on the front end of that ugly thing to make it look better!? GAH! It needs.. something. UGLY!
ZR2 and I'm in love again!
You got some actual pics? Ive heard terrible stories about the trannys in those. But, no vibrations at all?
I've heard the same thing, that they are having transmission issues. A friend of mine encountered a lady that couldn't get the key out of the truck because the truck thought the tranny was in gear when it was in park, couldn't start the truck either because of the same reason so he hit up another friend that's a mechanic and he said the colorados and canyons have been having a lot of transmission issues.
Thinking of trading my 2014 in on a 2010. Pretty sad when you look to downgrade 4 years because you know that era of truck is tough as nails and typically issue free. My 15 is my favourite truck I ever had, the 14 is my most hated truck I have ever had. Case by case basis. I think it a combination of cheaply manufactured torque converters, driveshafts, and rear axle shafts being made by 6 y/o kids in China. They build them cheaper and cheaper and charge more and more. Anyone with SLT's or Denali's shaking, or mostly the lower trims? My SLT is like silk but this WT is like your driving down as highway made of railroad ties.
900's were a step backwards from 800's the K2's are a far superior truck so your actually stepping backwards farther than you think....
Edited by mookdoc6
So I am finally rid of my shaky truck. I went through the BBB process and it was extremely easy and straightfoward. I had detailed notes of each visit, with who I spoke to, tech names, etc and it proved very helpful.
It was comical how GM attempted to defend the truck. I won't get into details other than the fact they told the arbiter this was their first ever complaint about the vibrations. I almost fell out of my chair.
Anyone with a vibrating brand new truck should definitely go through the BBB as soon as they hit their state lemon law requirements. I was awarded a full buyback minus mileage that I had put on the vehicle.
Never again will I own a GM product and I have been extremely impressed with my RAM for the first month of ownership. GM consistently lied throughout the entire process and was a complete pain to deal with.
Good luck to all and if you want any more info about the BBB process just send me a quick message
Actual pics? Those are actual pics of my truck...
No, zero, zilch, nada vibrations at all and the transmission is working very well. Granted, it has 288 miles on it so far but I actually really like the 8-speed for shift quickness. I think it doesn't suit some peoples driving style but I've had no trouble.
Well you had one pic up there and it looks like it's from a magazines so lol
I can't believe you said that. The 900s are by far the best generation truck GM has made. I went from an 09 to a 2014(worst generation) back to a 2009 Avalanche.
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
