On 6/25/2019 at 11:10 AM, Serge Messier said:
SOLVED FOR ME: I have a 2014 Silverado 5.3L LTZ and I have the stupid shake issue like so many of you. Oddly enough, I also have weird shifting like clonks which the US class action lawsuit only mentions 8 speeds when i have a 6. I road forced balanced the wheels\Tires and I have 3 sets of wheels so I know the vibration was not caused by one set. I tried tightening the leaf springs and it reduced the vibration but made the ride stiffer at lower speed.
The solution for me was adding a AFM disabler from Range technology. The vibration is gone and the transmission shifting is now smooth. It's only been one day and I am so happy, that I wanted to share.
I do love the GMC Sierra AT4 with a 10sp but don't need the 6.2L so the rumors that 2020 Sierra\Silverado 5.3L will come with the 10sp is great.
If you put it in manual shift with it set at 5 to avoid AFM did the vibrations go away or did it take the Range device to stop it?
What a bunch of bullshit There is no way that the AFM disabler from Range technology stops the vibration issues in these trucks He must be a salesman
Last time I spoke with my service writer I told him about the vibration.. At the time I had oem 22" wheels with 285/55's.  He said that they were probably causing it.  So I put my stock wheels back on and took a video at around 75mph.
Thanks for all the good posts.  Until this forum post, I thought mine was the only one that did this.  I have a friend that has a 2016 GMC SLT, 1/2 ton 5.3 (I have a 2016 4.3) and she has the same vibration issue.  I am hopeful for a resolution, this is the only issue that frustrates me on this truck!
I am not a salesman. I am an idiot like everybody else that had a vibration and have been reading these forums and watched a bunch of videos. I tried a few things with no success and found a solution that works for my truck. I did try COR's thing about driving in M5 but the vibration wasn't as bad but the transmission shifting was not pleasant.
Just like the other 832 pages of this thread, take the info you want but don't send out bad vibes you troll.
I tried M5 with my '16 5.3 and it vibed.  Vibes in neutral at 70ish too.  Apparently GM fixed it in the '19 models.  So what's the big secret GM??  They won't say because they're assholes.
After we have a large enough sample size of no confirmed issues on the T1 platform with plenty of miles on the road, it would be amazing if someone out there could thoroughly document the changes to the frame/driveline/etc between the 2 and try to conclude what may have been the issue on the K2's. Other than that, we may indeed never get a definitive answer on this topic.
My oversized aluminum driveshaft did fix my vibrations along with a set of yukon axles . However i do find that the center flip up consoles are very shake prone .
I would love to know if anyone with a flow through center console has ever complained of "THE SHAKE " .
The T1 is a completely different truck from the wheels up including suspension geometry, frame, etc. So the change you want to identify is the Entire Truck.
Indeed, what I was getting at is that there is a component or components that are different that are not causing this issue on the T1 (knock on wood). If it’s the relationship of all the components on the K2 causing it, then so be it. It’s just my inquiring mind that’s curious if it can be pinpointed.
2018 Silverado with the factory 20's and continental crosscontact tires. When I first hit 75 I swear drinks will come out of the center console much worse than the video above and at 80 it actually makes me nervous. It's the first time I have had it on the interstate and have a service appointment later this week. At only 1500 miles and a month of ownership I'm not liking what I have been reading here.
2018 Silverado LT 1500, 5.3L 6SP
Edited by Raze
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
