22 hours ago, epstein said:
did your vibration come back after the axles and driveshaft were replaced?
Brian
No mine is good . Center console just shakes on bumpy roads now going to do a center console swap soon .
2017 RCSB Silverado 1500 4x4----On my 3rd set of tires now..  It's NOT the tires!  GM needs to make this right as I'm a loyal GM product buyer/user BUT I will change hats if they keep dragging this on.  Get me a new STEEL driveshaft and we can go from there.
HA.  What makes you think your loyalty to GM means anything to them?  You are replaceable.
Valid point.  Customer service appears to have gone out the window in the name of shareholder return.
Yeah about 15 yrs. ago.
Sent from my SM-T580 using Tapatalk
I just took my 2018 Silverado 1500 back to the dealer for this vibration issue They replaced the torque converter a few weeks ago with no relief Can't wait to see what they come up with this time
Just a little update on the truck because i have had a few guys message me and ask . Truck has been very smooth still since changing the driveshaft to a new aluminium one piece and swapping in the Yukon axles .
Had my tires road force balanced last week because i lost some wheel weight off-roading and what a difference that has made truck feels smoother now then the day i bought it .
Hope this helps others .
On 8/5/2013 at 8:11 AM, ChevyTech77 said:
Either the tire/wheel assemblies have excessive radial force variation, the rear driveshaft (propshaft) is out of balance or the right side engine mount needs to be shimmed 3 mm. Those are the only vibration issues that I have seen with a K2XX truck.
Can you tell me what is the test to determine if you need a 3 mm shim for the engine mount?
What I find interesting about this issue is that some days, I take the same road, go about 78-80 mph and have major vibration.  Other days, same road, same speed and NO vibration.  Is it possible that road heat, heat outside, etc can play a role in how much vibration there is?  The other night I had none but previously that day on the same road during the day I had the normal (what I am used to) vibration.  Just curious if mine is the only one that is intermittent.
My 14 Denali is the same way. Sometimes it’s great sometimes it shakes really bad. Same roads. I just got my truck back from the dealership. I replaced the tires, pad, rotors and CV joints before taking it into the dealer. From my experience they will place blame anywhere they can. Perfect example they told me my new tires were the problem. I told them no it’s the exact same vibration as before new tires. They replaced quite a few parts in the trans and it still does the same thing.
I just noticed they said my tires were starting to cup. The new tires didn’t even have 300 miles when I took it to the dealership. My old tires didn’t wear uneven or have cupping. Frustrating.....
That's ridiculous!  They're brand new!  The sad thing is, when I bought mine new in June 2016, I bought some used rims and thought the vibration was due to a bent rim.  So I bought a whole new rim and still had the vibration and got rid of the tires and the wheels thinking that would solve it (before I knew about the vibration as an issue for most of us).  Now I run  new black 22's and tires and was convinced I screwed up something on my side because of the whole rim issue and it's something GM didn't do right.  And because I didn't know it, I never asked for anything to be done, I thought it was my RIMs.  I am hoping for enough complaints that they'll be forced to do something.  Until then, I will just keep driving it, vibrations and all!
2016 1500 Z71 Chebby…. dealer told me the vibe was from the "aggressive" tread of the Bridgestone Duelers.  Aggressive tread?!?  WTF, apparently he believed I just fell off the cabbage truck.  Needless to say, no resolution to the problem.  Good thing is (I guess), the truck only rarely vibrates.  And only at highway speeds after driving for 20-30 or so minutes.  Something, maybe the tires (not aggressive tread related), gets warmed up and causes or leads to the vibration.  Prolly will be my last GM product after 50 years of GM for 95% of my vehicle purchases, unless they step up.
Just took mine back to the dealer for shaking between 40-75 mph 2018 LTZ 5.3  6 speed  2wd So far the dealer has in this order changed the torque converter. changed the motor mounts. road force balanced the tires. scratched up one of the aluminum rims. changed trans fluid and replaced scratched up rim The shake is exactly the same as the first time I took it to them. I dropped the truck off this morning for another round
I would ask them to check the run out of the driveshaft and or the rear axle shafts .
Edited by Kylebr1
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
