Do we need these for both front seats?  I only ask because I never sit in the passenger.  LOL
I only ordered one kit. Lol.
Just ordered mine off ebay.  $3.00  and free shipping.  GM Parts wanted to charge $4.22 and then $15 for shipping.  DAMN!
On 6/17/2018 at 7:29 AM, 6.2_GMC_DEN said:
My seat was very loose side to side and front to back, it also made popping and creaking  noises especially when making turns with truck. After several trips to Dealer and paying for a half baked repair I had enough. I fixed my self and Installed washers on seat adjuster that moves the seat up and down and seat bottom tilt. The factory bolts threads bottom out and do not allow a tight fit and even with the plastic spacer the Dealer puts in per the bulletin there is still excess play and movement. See pics below with space I am talking about and pics on how to fix. I checked several other seats and they all have the same issue. This is a design flaw from the factory and I can't believe they have not addressed it.
this is the best fix for this problem works perfect
  • Thanks 2
This isn’t a movement question but has to do with the seat memory locations.  I’ve set my seats and the exit memory to my adjustments.  Every time i Get in the truck the seat moves forward.  Anyone know how to fix this?  Am I missing something?
Try swapping key fobs. You might have fob #2 :)
This.  You can also turn it off in the Settings menu.
Put some washers on that T-30 torx bolt, movement gone! Nice job to whoever figured that out. Worked great and took about 15 minutes.
Your welcome. Thanks!
It's amazing to me that people come on this thread ans continue to overlook this. Glad it fixed your issue. I have fixed hundreds of them.
Mine was clicking about every time I turned, braked....  I had seat frame replaced under warranty a few months ago, and it’s starting to do it again, I’m a bit disappointed, but seeing this makes me feel better about it since this truck won’t be under warranty for ever.
I just did this to my truck as well and it fixed the problem for good! This was after 3 trips to 2 different dealers while my truck was under warranty.
I put the rubber and hose clamps on years ago and have had to tighten em up a couple times since. They worked great but I had to keep the front part of the seat at it's highest point or it was still a bit loose. I did the washer fix this weekend and left the hose clamps and it is solid any way I go. I also tightened my G210 and 218 ground points to try a correct my Brake and Stabiltrac alarms and so far so good but I still think they will return. A shame we have to fix all these issues years later cause GM never could. My truck is nice but never again GMC..... I will be Yotaman again next time around. Thanks for the fix whoever "engineered it "
Yotaman
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
