They go around the rear view mirror and enclose the mount.
Me too!
Definitely wanting to see the console install. Power folding mirrors on an LT trim would also be excellent. Those are the only two things I really want on my truck that it didn’t come with. The dealer just didn’t have my truck with buckets on the day I went in and I didn’t want an LTZ this time mostly because I really wanted red hot color. So, here I am in want of console and mirrors. I know@pgamboa has the answers I am awaiting.
My truck didn't come with those and neither did the rear view mirror. Do you know the part number for it by any chance? I finally replaced the rear view mirror with the auto-dim one and it just looks ugly with the cables out.
I took some pictures to maybe help some people! I saw that there are three plugs up there! One for the rear view mirror and two I don't know what for. I'm hoping it's for the rear view mirror camera option! ?
Taking off that little console thing was easy. I got a little knife from my keychain and pried off the little tabs and they just popped off. Next, I used a T8 to unscrew the silver small screws then a T15 for the long black screws. I was popping off the main thing from the sides kinda prying it off again and it just popped off again -- too easy! I noticed two clips stayed on the frame and I think they're supposed to stay  there since the 'female' and looks like it grabs on to them?
The hardest part was screwing back those damn T15 screws. It took me like 30-45 minutes just trying to make them go in the center hole without being able to see. And theres a second hole on the inside corner where it was always getting stuck on. Patience and some beer made me not break the damn thing in anger. After that, the 2nd most hardest thing was peeling off the cable from the glue. I didn't want to use my knife in case I cut the cable so I was using a flat head to peel it off. This part took about 15 minutes. But all in all, an easy enough job! Hopefully the pictures I took can help someone recognize what those other two plugs are for!
PS: If you want a specific picture in higher resolution, let me know!
Edit: I’ve been thinking, I wonder if that big connector is for the homelink module. Would be cool to add the homelink module by plugging it in and just get the little plastic cover with the hole in it for the buttons to easily add homelink to the truck.
Edited by Semedar
  • Thanks 5
So I called my dealer to see if they can order that wire cover for me and I mentioned what those two other harnesses are for. He looked it up and said it’s for the windshield wiper and temperature sensor. So I guess there goes that rear view mirror camera thing. ?
Interesting, I guess it is possible to add rain sensing wipers?
Pretty much since they don’t even offer them as an option.
Tonight I just pulled my trim down to see if I had the wires for the auto dim rear view mirror and I do. But just like in Semedar's pics I also have the big grey connector right above where the home link buttons should be. I have a hard time believing it is not for home link. Maybe I misunderstood previous post about it being for rain sensitive wipers. Anyway I'm going to order my mirror.
Not for rain sensing wipers as it’s not even an option on the high Country trucks.
Can confirm, this simple method works. Taking off the console sounds more scary than it is, it goes back together very easily. Even the two front screws some had trouble with went right back in on the first try (maybe I was just lucky lol). Altogether in total it took less than 30 mins, what took the most time is prying all the glue off the wiring harness, mine was covered in it (see pic)!!
Thanks @Semedar for the pics - made it a lot easier to do it!!
Btw - easy test to see if it works (before putting everything back)  is by covering the sensor in the back of the mirror with your finger, you'll see it slowly dim, put truck in reverse and see it light up again, then back to Park to see it dim. Mission accomplished!!
On 8/23/2019 at 8:38 PM, JR09country said:
Could it be for sunroof controls?
Sent from my ONEPLUS A6013 using Tapatalk
I think you're right. I have the sunroof and only had one 'unused' wiring harness - rest was all plugged into the console.
Could also be for the power rear window (which I have also).
Edited by tinbad
So, It sounds like I'm screwed since I'm in a 2018 LT.
my mirror has OnStar only (manual tilt).
I'd love a mirror that did auto-dim, OnStar AND added Homelink...
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
